[17/01/16] - Campagna WolfPack
CAMPAGNA WOLFPACK
Sono a presentarvi la Wolfpack, campagna che forse alcuni di voi già conoscono, composta da 10 missioni concatenate tra loro, rispettivamente 5 del vol.1 e 5 del vol.2! I posti disponibili per la campagna sono di 14 player, senza la possibilità di aggiungere slot, quindi a numero chiuso. A breve posterò, d'accordo con i ragazzi dell'Armata Brancaleone, il calendario ufficiale delle serate dedicate a questa campagna, calendario che sarà DIVERSO da quello ufficiale del Clan. Ogni missione andrà completata con successo per poter passare a quella successiva (come penso sia giusto che sia) e di conseguenza il calendario potrebbe subire variazioni di volta in volta.
=== SITUATION ==========
SUMMARY
June 2034, Altis is in turmoil. The island has been cut off from the outside world due to economical and physical blockades. The local populous has grown impatient with the government and the AFF in particular. Several demonstrations have resulted in the deaths of tens of civilians.
The government was losing control rapidly and called in the help of CSAT. A mistake that would cost them dearly. CSAT saw a golden opportunity to get a much needed foothold in the Mediterranean area. The AAF requested a single battalion of CSAT Infantry. Instead CSAT send the entire 2nd brigade and soon CSAT outnumbers AAF by 11:1. Altis government realized that they lost control completely and stepped down. CSAT General Tehrani has since been in power and controls all of Altis and Stratis.
CSAT is now proven a serious threat to the European region. As diplomatic efforts have not lead to the anticipated result, NATO decided to send a rapid task force to free both islands from CSAT oppression.
.DEVGRU has been ordered by J.S.O.C. to take out several high value threads on Altis before the NATO campaign commences. Wolf has been tasked with executing 10 missions over a period of 3-4 weeks. Your first mission commences 11 June.
INTEL ON ENEMY FORCES
Our area of operation lies north of Athira. The area is not of strategic importance to CSAT. Signit has confirmed the presence of 1 infantry company. We also know of a SpecOp unit that is doing training maneuvers in the area.
NATO FORCES
Three troops:
One command troop - SSC, marksman, squadron paramedic and a recon/UAV specialist.
Two assault troops (AT) - Troop Leader and 4 Assault Specialists
There will be no support. This is a 'plausible deniability' op. We cannot offer any help or assistance if you get caught. You are on your own.
Our operation is the only operation on Altis. No other Bluefor present.
=== OBJECTIVES ==========
MISSION OBJECTIVES
Due to the sensitive nature of this mission, objectives will be given on a need to know basis once you have reached the RV. Our local on the ground will do an extensive briefing.
=== TACTICAL / EXECUTION ==========
CONCEPT OF OPERATIONS
The mission is of vital importance for the remainder of the campaign. Faillure is not an option. Make sure you are not detected. If possible, let EI pass by and approach the objective covertly.
Tactical MO and strategy will be briefed on site.
TACTICAL MOVEMENT
AT's will relocate in a bounding fashion unless otherwise ordered. Command troop will provide cover and support for the AT's.
Control points, BP's and routes will be briefed on-site
WEAPONS/FIRE SUPPORT
No support available.
SPECIAL OPERATIONS
No other operations available.
=== SIGNAL & COMMS ==========
RADIO COMMS
Command: CH 1
SQUADRON LEVEL (148)
Wolf: CH 2
TROOP LEVEL (343)
Wolf 1: CH 1
Wolf 2: CH 2
Wolf 3: CH 3
SIGNALS
White smoke - smoke concealment. No signal
Green Smoke - safe area signal
Red Smoke - hostiles area signal (position known)
Orange smoke - hostiles area signal (position unknown)
Purple smoke - Bluefor at smoke, hostiles near signal
Green chemlight - Safe/Searched (in buildings)
Red chemlight - Not Safe/Not searched (in buildings)
=== M.O.B. & LOGISTICS ==========
PLAYER RESPAWN / PLAYER JIP
Respawn available.
JIP is enabled. New players joint near their team.
PLAYER LOADOUT
Pre-defined, role-specific loadout
VEHICLE RESPAWN
No respawn available.
VEHICLE SUPPLY CARGO
Not applicable
TRANSPORT ARRANGEMENTS
The USS Pennsylvania will drop you off at position Zulu from where you'll insert using RHIB's to the RV point, approx 2 Mikes South West of Zulu.
Exfil to be briefed on-site by our local on the ground.
MOD NECESSARIE
CALENDARIO
  • 17-01-16 Wolfpack Vol.1 - Day 1
  • [DE DEFINIRE] Wolfpack Vol.1 - Day 2
  • [DE DEFINIRE] Wolfpack Vol.1 - Day 3
  • [DE DEFINIRE] Wolfpack Vol.1 - Day 4
  • [DE DEFINIRE] Wolfpack Vol.1 - Day 5
  • [DE DEFINIRE] Wolfpack Vol.2 - Day 6
  • [DE DEFINIRE] Wolfpack Vol.2 - Day 7
  • [DE DEFINIRE] Wolfpack Vol.2 - Day 8
  • [DE DEFINIRE] Wolfpack Vol.2 - Day 9
  • [DE DEFINIRE] Wolfpack Vol.2 - Day 10
Visto i pochi slot delle missioni considererei di dividere equamente gli slot, 7 per clan, con la possibilità di occupare posti liberi da chi si aggiunge oltre i settimo posto.
9GU Slot
  • 1. Aarkis
  • 2. Nikmuff96
  • 3. UncleBob1982
  • 4. Didotto
  • 5. Geeno
  • 6. Eagle_Flying
  • 7. Jimmy
Re: [17/01/16] - Campagna WolfPack
Confermo la presenza :pollicione:
Didotto
Post by Didotto »
Gino
Post by Gino »
Presente al 50% perché pare che martedì parto daccapo
Inviato dal mio HTC Desire 820 utilizzando Tapatalk
Lt. GeeForge
Inviato dal mio Nexus 5 utilizzando Tapatalk
Didotto
Post by Didotto »
Rettifico la mia presenza (forse ci sono al 50%)
Jimmy
Post by Jimmy »
Nikmuff96
Post by Nikmuff96 »
Ritrovo su TS alle 21? Se sì, ci dovrei essere al 50%, vi faccio sapere meglio nel tardo pomeriggio.
Inviato dal mio Motorola Moto G utilizzando Tapatalk.
"Memento Audere Semper"
Ritrovo alle 21/21:10 per partire alle 21:30 massimo
Inviato dal mio iPhone utilizzando Tapatalk
Pipankov
Post by Pipankov »
io vorrei essere presente, ma ho visto che c'è un solo slot libero e Jimmy non è inserito...?
comunque mal che vada mi offro come riserva :balla:
a dopo :LOL:
